https://grafana.vtitel.net/d/Test3/job-status?orgId=1&theme=dark
in iframe URL I want to remove left side bar and top header only so is there any options to remove those panel.
I tried kiosk view but this view is remove filter panel as well so kiosk view will not work I need to remove sidebar and header panel.
please suggest if is there any option available in grafana.
Thank You
