Hi, I’m using Grafana with InfluxDB SQL as the data source, and I’m outputting data values by specifying codes in the select field. I’m using two codes in the select function to output data, where the x-axis represents time and the y-axis represents the values corresponding to the codes.
I want to calculate [(end time of the first data)-(start time of the second data)] (Red Points data - Blue Points data) based on the data points. Is there a way to convert data points to time values and output only the time values?
Any help would be greatly appreciated!
And Thank you for reading this and I hope you have a great day!
