I can't set dual y-axis
I use grafana 8.1.2 on windows;
I plot two lines(A and B) on one panel and I want to set line A’s y axis on left and B’s on right; I set as below, but not work.
Hi @south_wind
Can you share your query screen? You should have A and B as separate queries.
Hi @grant2
The queries are as below:
my Query Language:
Thank you for your reply.
If you change the override to “Fields Returned by Query” and then select B, does that help?
I have tried and this doesn’t work;
If I set A to be ‘left’, then both A and B are ‘left’;
If I set A to be ‘right’, then both A and B are ‘right.’
Only thing that I can think of is that your version of Grafana has some bug in it. Can you upgrade to the latest version?
Thank you @grant2
I have upgrade into the latest version and now I can set dual y axis.
