Grafana OSS 9.0.3 -
I wanna delete the unit un my grafana panel, however I cannot delete it anymore. -
before, I just simply delete it using a “backspace” or delete on keyboard. -
What happened?
The options doesn’t allow me to delete it. -
I should have the ability to delete the unit. -
N/A -
N/A
I have noticed that some fields in Grafana are not always easy to change, and this appears to be one of them. I would just choose Number and then you should be good to go. The “blank” option only seems to be available before you have chosen any unit of measurement.
Number really works.
Lower version of grafana allows “none” or empty.
Thanks for suggestion!
Regards,
Henjoe
