how can ı add the Storage Metrics into grafana, could anyone help me to do this?
I would suggest to check snmp plugins to perform queries to your storage array.
One way is to use telegraf + influxdb, then use some of the Grafana SNMP dashboards to get you inspired.
Hope it helps.
Good Luck
