V8.0.4 -
When using confidence bands, I want the lower confidence band to be zero when it returns a negative value. -
Trial-and-error messing with the confidence settings themselves, as well as attempting transforms for values less than zero. -
What happened?
Breaks graph display -
My hope is to all the lower confidence just go to zero when it calculates a value in the negative ranges. Since it is a confidence of power, it will never be less than zero watts. -
alias(holtWintersConfidenceArea(movingAverage(keepLastValue(scale(monitor.power.probe3, 0.5), 10), ‘30min’), 6, ‘7d’, ‘1d’), ‘Confidence’)
Grafana itself is not erroring. I suspect it is the way I was attempting to set the confidence values. -
None that I could find
in graphite itself is it possible to do an inline iif statement? not sure of the language
kw < 0 : kw + (kw * -1) ? kw
ie
kw = -300
-300 + (-300 * -1) = 0
I don’t think so. Since it is a calculated value, and gives two separate confidence bands, I don’t believe I can do any kind of math against it.
