Good Day!
I am using grafan Json api plugin and I want to use time range diapason on this plugin in order to filter result by date
I know that we can use time range by $__timeFilter, $__timeFrom or $__timeTo, but how to use time range in terms of Json plugin, can anyone give some idea, please?
or can anyone suggest any other json plugin?
for example I used Infinity plugin but with that also could not manage to use time range
I was wondering the same thing this morning. If this is possible it’d be great to see an example.
yes this plugin,
or can you suggest any onther json plugin that works with time range?
that should work. Can you please post your sample data?
well, I connot upload json file, this site is not letting me do so,
If you know the solution, can you please demonstrate it step by step?
“login”: “CALL1”,
“full_name”: “CALL1”,
“login_date”: “2022-11-28 17:44:24”,
“user_type”: “Dialog”
“login”: “CALL9”,
“full_name”: “CALL9”,
“login_date”: “2022-02-03 12:35:59”,
“login”: “EMAIL”,
“full_name”: “EMAIL”,
“login_date”: “2021-02-03 18:04:10”,
“user_type”: “Service”
“login”: “CALL7”,
“full_name”: “CALL7”,
“login_date”: “2022-10-04 12:08:38”,
“login”: “HISTORY_USER”,
“full_name”: “HISTORY_USER”,
“login_date”: “2021-02-22 17:13:07”,
“login”: “MOBILE”,
“full_name”: “mobile”,
“login_date”: " 2022-10-04 08:24:22",
“login”: “CALL5”,
“full_name”: “CALL5”,
“login_date”: “2022-12-04 18:57:23”,
“login”: “CALL8”,
“full_name”: “CALL8”,
“login_date”: “2022-11-04 08:24:22”,
“login”: “CALL6”,
“full_name”: “CALL6”,
“login_date”: “2022-11-04 09:14:45”,
using jsonata
You can play with it as you want with your time range here
https://try.jsonata.org/pjT_VFos9
($f := $; $filter($f, function($v, $i, $a) { $v.login = "CALL5" }) )
and transform
thanks, but this is not working with grafana time range,
it would be better if it worked like this
yosiasz
December 6, 2022, 7:08pm
11
are you sending these values to your api endpoint?
I too tried using the $__timeFrom such as below in a JSONata field:
That does not work. Hard coding a date value there does however.
Edit* Misread your reply a bit there. Sounds like you tried this as well.
yosiasz
December 6, 2022, 7:28pm
13
it is hard to test it in grafana. I would test things out over in https://try.jsonata.org/
Also are you dates UTC?
yosiasz
December 7, 2022, 7:25am
14
Are you asking about sending those values to your api as parameter or filtering the data from the api within grafana ?
It’s been a while, but you can use the following macro to solve your problem.
$__isoFrom()
$__isoTo()
grafana-json-datasource
