Grafana v9.1.0 (82e32447b4)
- What are you trying to achieve?
Visualize counted timeseries data
- How are you trying to achieve it?
Use Time series panel type with the following query:
count(count_over_time({app="app"} | json | event = `123` [$__interval]))
Also set Decimals option in Standard options section to 0 to prevent showing decimal points
- What happened?
The panel is showing int numbers multiple times in y axis as shown in the screenshot below:
As currently it only showing one bar with the value of 2, I expect y axis to simply have only the starting value of 0, and highest value of 2.
- Can you copy/paste the configuration(s) that you are having problems with?
The query above.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No.
- Did you follow any online instructions? If so, what is the URL?
Yes.
