How to visualize a value as text
With what visualisation and how do I visualize a boolean value as text?
for example : a “true” value should become “valve on”, a “false” value should become “valve off”.
I already know that I can use value mappings for this, but what kind of visualisation do I use?
At first I though I could use a stat, but it says “no data”. When I try a “table” visualization I see a “true” value visualized as “oven on”. So in this visualization it seems to work.
This is my KQL code :
adt_history
| where Id == '$Lijst_ovens'
| where $__timeFilter(SourceTimeStamp)
| where Key == 'rtoValve1.open'
| project SourceTimeStamp, Id, not(value=tobool(Value))
| top 1 by SourceTimeStamp
Or maybe an “icon” visualization.
You may try
thanx for the tip, unfortunatly I do not have administrator rights on my Grafana deployment, so I cannot install any new plugins…
