How to use Sankey panel
    v9.3.6
    I try to use Sankey panel with an InfluxDB source
    I try to guess the input Sankey format…
  • What happened?
    Nothing is displayed
I created a test table to send to “Sankey panel” like :
table result level1 group string level2 group string val group long
0 scr1 dst1 10
1 scr1 dst2 100
Does anyone know how to use Sankey panel with InfluxDB ?
BR
Is there anybody who have used this plugin with InfluxDB ?
Or any other trick to plot a Sankey diagram on Grafana using InfluxDB ?
Best regards
I have the same problem.
Can anyone help?
