i dont have to show diagram or topology create in url
The released plugin is currently bugged - you can try to clone my fork https://github.com/briangann/grafana-diagram
which should fix the problem.
Hopefully the PR will get merged and it will start working out of the box again
Thanks!
Brian
dear bkgann
i try clone,but same i dont have show topology in plugin from URL. u have tutor?
Let me try another test and see what happens. The current code in my fork works, but I may have had to disable browser CORS for it to work.
How mr.bkgan my problem
why my problem sir,
I really need
Hello All,
I need help on Grafana Diagram Panel https://grafana.com/plugins/jdbranham-diagram-panel.
I was able to create Diagrams using Mermaid Syntax in the Content area provided.
Now, i want to pass Mermaid Content from any URL or any other way like keeping Mermaid file on a Server & then calling it, as we want to change the Diagrams dynamically.
Any help on this topic will be really appreciated.
Have you resolved this issue?
I have the same problem.
Hi do anyone have resolution for above issue…??
Hi Anshul… Have you got any solution for this?
Sorry. Still i am unable to find any solution for same. Our team had stopped working on it.
