I have grafana to display my sensors data and influxdb to store the data tha come from these sensors. Is it possible to show the status of my sensor on grafana for example i can add a field in influxdb with on or off how to display only on with a green color and off with a red color and display only the last received data from my sensors without showing the time
Related topics
| Topic | Replies | Views | Activity | |
| Display the stat of a machin ON/OFF On statue panel grafana | 3 | 5079 | April 14, 2021 | |
| Openhab, Grafana & InfluxDB2 - State Timeline & Status History for Simple motion sensors | 4 | 393 | October 21, 2024 | |
| Lookup status codes from SMA photovoltaic inverter | 3 | 295 | February 8, 2024 | |
| Best way to display open/closed for doors and windows | 4 | 3193 | August 27, 2021 | |
| InfluxDB, Home Assistant & Grafana - Energy & Power | 4 | 4439 | January 30, 2022 |
