I have a influxdb and want to show the downsampled values on grafana.
InfluxDB Version: 1.2
Grafana Version: 4.2
I have created a influxedb database:
> CREATE DATABASE "mydb3_rp" -
Then I have created an retention policy:
> CREATE RETENTION POLICY "1week" ON "mydb3_rp" DURATION 1w REPLICATION 1 -
Then I have created the continuous query:
> create continuous query "cq_10" on mydb3_rp begin select mean(\*) into "mydb3_rp"."1week".:MEASUREMENT from /.\*/ group by time(10m),* end -
Then I put some data into the database. When I finished and want to see the saved values with the influx command line tool :
select * from cpu1 name: cpu1 time cluster node value
---- ------- ---- ----- 2017-05-03T17:06:00Z cluster-2 node2 2.9552020666133956 2017-05-03T17:07:00Z cluster-2 node2 -1.5774569414324822 2017-05-03T17:08:00Z cluster-2 node2 0.16813900484349714 2017-05-03T17:09:00Z cluster-2 node2 1.244544235070617 2017-05-03T17:10:00Z cluster-1 node2 7.833269096274834 2017-05-03T17:10:00Z cluster-2 node2 -5.440211108893697 2017-05-03T17:11:00Z cluster-1 node2 -6.877661591839738 and so on...
- And now I want to see, if the continuous query was working and did the aggregation:
select * from "1week".cpu1 name: cpu1 time cluster mean_value node
---- ------- ---------- ---- 2017-05-03T16:45:00Z cluster-1 1.074452901375393 node1 2017-05-03T16:45:00Z cluster-2 1.477524301989568 node1 2017-05-03T16:45:00Z cluster-1 0.8845193960173319 node2 2017-05-03T16:45:00Z cluster-2 -0.6551129796659627 node2 2017-05-03T16:50:00Z cluster-2 -1.6457347223119738 node1 2017-05-03T16:50:00Z cluster-2 0.6789712320493559 node2 ...and so on
- Now I go into grafana and define a query like this :
FROM 1week cpu1 select field(value)
There are - No Data Points
