“version”: “9.3.0-beta.1” -
Use Canvas plugin and I need to add background color for string metric. The color is changed according to the string.
Example:
Production => Green color
QA => Yellow color
Development => Orange color
etc… -
I added item as metric value that is string. For now I use another numeric metric to set background that is not related at all. - What happened?
I work, but not the good way to do that. Since I use one existed numeric value as “Response time ms”. This is not realted at all to the Environment string : Production, QA, Dev… - What did you expect to happen?
How I can set the threshold on string metric that work as expected independently. - Can you copy/paste the configuration(s) that you are having problems with?
N/A - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors - Did you follow any online instructions? If so, what is the URL?
I didn’t find accurate data in the confluence except for :
Canvas | Grafana documentation
Any update on this please?
You can follow our document
and if you are still facing any kind of issue or problem you can contact us for more assistance
