How to set max value of gauge panel by using query
Hi, how can I make this gauge display properly? I have just 13 devices, but the gauge is showing 100.
Thanks
Gauges has Min - Max range:
So just set Min, Max configs for your case.
of course. but the number of devices can change every day, I need it to set to COUNT of the devices
This is example for Stat I have with count of devices and it works
SELECT COUNT(DISTINCT("device_id")) FROM (
  SELECT LAST("status") AS "status" FROM "heartbeat" GROUP BY "device_id"
Add it as third query and then add Config from query results transformation, where you use result from this query to set Max config of the panel. Example:
it helped with the ‘inner green’ but the main thin one is still 1-100
Provide reproducible example first,pls.
