How to set color schem dark to light for bar gauge?
Hello, I am showing some % value in bar gauge like below but i want it exactly opposite. so if its 51% then from left to right it should be green / dark green and then should get lighter or white for remaining 50%.It should exactly show that this reference point or line is 51%.
like this?
@sowdenraymond :Yes.exactly.
To achieve the desired effect, you can set the bar gauge to start with a green color on the left (representing 51%) and transition to a lighter color (white) on the right for the remaining 49%. Adjust the color gradient so that the left side is dark green for the percentage, and the right side fades to white. This will visually indicate the reference point at 51%.
@nickfreedy : how to set those colors ?
@sowdenraymond :could you please help? I am looking out for something you posted.
Hi, you’re using Shades of color color palette but you’re setting colors in thresholds. I guess you should change the color scheme to From thredsholds or something like that.
The original answer was also made using Gradient Bar Gauge, not Retro LCD (I tried with Retro LCD and couldn’t achieve the smooth gradient without setting numerous thresholds).
@sowdenraymond :Thank you so much !! I am able to get the desired effect now.
