How to Set a Default Value for Dropdown in Data Manipulation Plugin in Grafana?
I need to set a default value for a dropdown in the data manipulation plugin, but I’m uncertain about the steps involved. I’ve checked the plugin’s documentation and explored Grafana’s settings, but I couldn’t find a clear solution.
@utkarshsalunkhe If you are not using the Initial Request, you can update default values using the special Default button, which is hidden by default.
  1. Enable the save defaults button.
  2. Enter and select values in the form.
  3. Click the Save button to save values to the dashboard.
Let me know if it works. We are working on improving documentation and new YouTube tutorials for Data Manipulation v3. We plan to premier the tutorial next week.
thanks ,its work .
