How to send noisy topics to the end of the list?
  • Grafana v11.2.2+security-01
  • Trying to stop noisy topics that are not monitored from cluttering my topics list at the top. I am looking for a way to send them to the bottom of my list when I view my panel.
  • This is where I need help. I am trying to make sure that the graph is visible on my panel but I want the topics to be pushed down to the end even when I try to sort topics in ascending or descending order by ‘last’ or ‘max’ values. I want a bunch of topics to get ignored and stay out of my way in the topics list until I need them.
Welcome to forum @gshriram2019
What is your datasource and 2gat visualization are you using
Prometheus
Hello @gshriram2019 please share the table view screenshot for better understanding.
or you can try this use Add field from calculation and decide prority like important = 0 , Noisy = 1 then apply sory by on prority
or if you don’t want to see noisy topic then use Filter data by values and exclude the noisy metrics add condition according to your requirement.
