hey gus, i want to know how to send k6 performance metrics to telegraf. Can you tell me how to do it?
I have deployed telegraf on a k6 instance, and did the above configuration.
However, I found that after performing the stress tests, there are no performance metrics in telegraf’s database, telegraf seems to be used only to collect metrics such as CPU and memory…
Hi @sunnini
Did you have a look at Does k6 support telegraf? - #3 by mstoykov? From your screenshot it looks like you are actually using InfluxDb underneath.
Let is know if you still have doubts.
Cheers!
