v9.2.2 -
Send alerts generated by Grafana to Zabbix -
Configuring alert rules, contact points and notification policies -
What happened?
I’m not sure if this is the way to go, and if you need some other layer to run a script -
That the webhook contact point sends the alert data (Json) directly to the zabbix API -
No, as they have sensitive data -
I didn’t get any errors -
Configure the webhook notifier for Alerting | Grafana documentation
Zabbix does not have a HTTP Event Receiver on it’s side, and the Grafana’s Webhook notifier needs a HTTP Event Receiver. Then they’re not compatible. You’re gonna need to develop Middleware between both to make it work.
