Grafana v7.5.17 (84411794f3)
Windows 11 -
When creating a variable within Dashboard, the preview value should be no duplicate. -
NA -
What happened?
In the “Preview of values”, there are many duplicates. Here we use color to represent different values. There are 2 black colors, 2 red colors, 2 green colors, and 3 yellow colors. -
Each value of preview should be unique -
Please see above screenshot. -
No -
No
In Grafana v7.5.17 on Windows 11, encountering duplicate values in variable previews can be resolved by reviewing your data source and query.
First, verify that your data source doesn’t contain duplicates. Check the variable query to ensure it doesn’t inadvertently generate duplicate results. You may need to adjust the query or use variables for filtering.
Data preprocessing outside Grafana might be necessary to remove duplicates if your data source lacks this capability. Additionally, consider upgrading Grafana for potential bug fixes.
Seeking assistance from Grafana’s community forums or support can provide tailored solutions for your specific data source and use case.
What do you get when you run the same lucene query in kibana for example?
