How to query grafana with influxdb so see values which include specific string text
    Grafana 7 and influxdb 1.8 on linux Rhel server
    How to query in to Grafana with Influxdb so see values which include specific string text
    I have tried following and similar query commands:
SHOW TAG VALUES WITH KEY = "name" WHERE "name" = /[ir]/
Idea is I want to get all results which contain string
  • What happened?
    Cant achieve wanted result
    I expect to receive back all the URL’s in other words endpoints that contain string
Welcome
What if you tried
=~ /*ir*/
Not sure if you are looking in the beginning or end or in the middle anything containing ir
Hey @yosiasz !
Thanks for response, but unfortunately that does not return only urls with , still returns all results.
is full word in endpoint, in example:
web.com/dostuff/ir/getdata
so if url contains "ir"i would like to see only those, however some contain ‘ri’ and those are returned as well :confused:
Thanks a lot!
This helped :slight_smile: !
