Hello, How to Optimize First Access Grafana Load Slow,
The first loading time is about 20 seconds.
What are the mature and optimized solutions for the community?
If I do a full page reload of a Grafana installation on a local LAN it’s 1.3 seconds. After that it’s about 1second.
For doing a full page reload on a server on the other side of the globe (https://play.grafana.org) takes about 2 seconds.
So your 20 seconds must be to due very slow internet connection or do you have a custom build of Grafana that is not optimized? All the default release packages are optimized but you have a custom build you need to run yarn run build
to create an optimized frontend build.
gzip
Enable ini option enable_gzip
