11.1.14 - What are you trying to achieve?
Sometimes, CloudWatch metrics have null data due to timeouts. I want to add another data source to backfill the missing data.
I have custom metrics that CloudWatch should receive every minute, but I noticed null data for a few minutes in the CloudWatch console. I rechecked, and the data was fine during that time. I would like to fill in the missing data. Since I can’t modify what I receive from the CloudWatch API, how can I achieve this to fill the gaps?
For example, a few default metrics had null data, but the system was functioning fine during that time. What’s the best way to use a mixed data source to backfill that missing data from cloudwatch plugin?
