Hello ,
I’m trying to graphe the VM that i have created on AWS on GRAPHANA.
The issue that i have is that I can’t reconize easylly my VM on graphana as i have only a ID d’instance.Coud you help please ?
That’s impossible because CloudWatch API doesn’t work with “VM name” (the correct term is tag Name). But you can at least filter by tag Name - check & update existing dashboard for your needs, e.g.:
