- What are you trying to achieve?
I would like the units of a summary metric to be dynamic enough to show one unit if the value is smaller, and another if larger. In my particular example the metric is distance and I’d love “feet” for smaller distances and “miles” for larger distances"
This is similar to how duration metrics are shown; the unit varies between seconds, minutes, hours, days depending on the value itself.
Is it possible to do this using a distance metric?
I have attached a screenshot of my Stat panel. The “distance traveled” variables are the ones I’d like to show in miles when the values are over, say 3000 feet.
