Grafana v10.2.0 - What are you trying to achieve?
I want to create a graph with multiple labels DROP DOWN in Grafana as a “filter” for filtering desired data. 3 of 4 variables work without any issues, The fourth one is the problematic one, because I do not know how to use this fourth one “ALL” or just one from this variable.
When I chose only one value from this variable - it worked and data were filtered in a graph. But when I want to choose ALL of those my metric “vanishing” on the graph and is no longer available to display.
- Can you copy/paste the configuration(s) that you are having problems with?
Name of Variable: V1
Definition: label_values(Processing_msg_cnt, V1)
Name of Variable: V2
Definition: label_values(Processing_msg_cnt{V1=“$V1”},V2)
Name of Variable: V3
Definition: label_values(Processing_msg_cnt{V1=“$V1”,V2=“$V2”}, V3)
Name of Variable: V4
Definition: label_values(Processing_msg_cnt{V1=“$V1”,V2=“$V2”,V3=“$V3”},V4)
**Also I checked the box for “Include All option” on V4
Maybe I should use regex in the variable setup?
Regex:
Optional, if you want to extract part of a series name or metric node segment.
Named capture groups can be used to separate the display text and value (see examples).
If yes could you guys help me with this? I did not find any solutions to how to do it properly.
- Did you follow any online instructions? If so, what is the URL?
I found something like this, but I see this guy used GRAPHITE, I am using Victoria Metrics.
https://play.grafana.org/d/000000056/templated-dynamic-dashboard?orgId=1&var-app=fakesite&var-server=All&var-interval=1h
This way did not work.
Could you please help me with that? I am using metrics from Victoria Metrics and yes those labels exist for all of the metrics that I am using in my graph.
