How to integrate Grafana Pyroscope with OpenTelemetry Java Agent and Alloy setup?
We have an OpenTelemetry Java agent configured on our Java application, exporting data to Grafana Alloy.
From Alloy, we are successfully sending:
  • Metrics → Prometheus
  • Logs → Loki
  • Traces → Tempo
This setup is working fine.
Now we want to enable continuous profiling using Grafana Pyroscope, which we have already deployed.
Could you please guide on:
  • How Pyroscope should be configured in an existing OpenTelemetry + Alloy setup
  • Whether profiling should be enabled via the OTel Java agent or a separate Pyroscope agent
  • How Alloy should be configured to receive and forward profiling data to Pyroscope
Any sample configs or best practices for this integration would be very helpful.
