What Grafana version and what operating system are you us
Latest -
Integrate prometheus with dapr metrics and use provisioned dapr dashboards -
Configuring prometheus.yml and a prometheus datasource for the dapr dashboard yml files
- What happened?
I don’t see the prometheus icon under browse next to the dashboard as I do for cadvisor
See my dapr provisioned dashboards populated with live data from scraping dapr metrics on port 9090
- Can you copy/paste the configuration(s) that you are having problems with?
global:
scrape_interval: 15s
scrape_timeout: 10s
alerting:
alertmanagers:
Load rules once and periodically evaluate them according to the global ‘evaluation_interval’.
rule_files:
- “first_rules.yml”
- “second_rules.yml”
scrape_configs:
The job name is added as a label job=<job_name> to any timeseries scraped from this config.
- job_name: ‘prometheus’
static_configs:- targets: [‘localhost:9090’]
- job_name: ‘dapr’
scrape_interval: 5s
- job_name: ‘cadvisor’
static_configs:- targets: [‘cadvisor:8080’]
labels:
alias: ‘cadvisor’
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no errors
- Did you follow any online instructions? If so, what is the URL?
