How to insert raw html (hyperlink) to email message
Hi! I used in alert_resources.yml the code like this:
template: |
    {{ define "alert.additional_details" -}}
       {{ if .DashboardURL }}
      - <a href="{{ .DashboardURL }}">Dashboard</a>
      {{ end -}}
Also I tried:
[Dashboard Url]({{ .DashboardURL -}})
Both returns me the output as it is like:
[Dashboard Url](``http://myurl``)
And I want to see hidden hyperlink like this:
hi @mihalt
here’s an example of a working template that uses the dashboard url element in a template
https://grafana.com/docs/grafana/latest/alerting/configure-notifications/template-notifications/examples/#print-a-link-to-a-dashboard-with-time-range
hope it helps you as a reference for your use case
I am sorry, but looks like, that no. You offer to do
Dashboard: http://localhost:3000/d/uiyahbsdaubsd?from=1740070380000&to=1740071880000
And, as I said in the topic, I want just
Dashboard url
I have huge 10+ lines links sometimes. And it is very hard to scroll to next parameters that I want to see in the message.
