Currently use
def send_to_graphite(tuple):
payload = pickle.dumps(tuple, protocol=2)
header = struct.pack(‘!L’,len(payload))
message = header + payload
print ( tuple )
now = datetime.datetime.now()
sock = socket.socket()
sock.connect((graphite_server, graphite_port))
sock.sendall(message)
sock.close()
return()
where an example tuple is
('my.data.of.interest, (‘now’, ‘data_point’))
if I want to add a tag, say
tag_interesting=yes
where is this added to the original tuple ?
Hello @cadencep45
Might this be of help
https://graphite.readthedocs.io/en/latest/feeding-carbon.html
To address these issues, Graphite also supports using tags to describe your metrics, which makes it much simpler to design the initial structure and to evolve it over time. A tagged series is made up of a name and a set of tags, like “disk.used;datacenter=dc1;rack=a1;server=web01”. In that example, the series name is “disk.used” and the tags are “datacenter” = “dc1”, “rack” = “a1”, and “server” = “web01”. When series are named this way they can be selected using the seriesByTag function as described in Graphite Tag Support.
When using a tagged naming scheme it is much easier to add or alter individual tags as needed. It is important however to be aware that changing the number of tags reported for a given metric or the value of a tag will create a new database file on disk, so tags should not be used for data that changes over the lifetime of a particular metric.
Good link, but from amended tuple to
('my.data.of.interest;tag_interesting=yes, (‘now’, ‘data_point’))
but can not see any data in grafana. Where should the tag data be visible - in the whisper file directory ?
