I have installed Loki with Helm that is using MinIO as storage.
helm upgrade -n loki --create-namespace --install loki grafana/loki -f loki-values.yaml
Now the MinIO storage is full and I would like to expand it.
I adjusted my loki-values.yaml
minio:
enabled: true
persistence:
And I get the error when upgrading with Helm
Error: UPGRADE FAILED: cannot patch "loki-minio" with kind StatefulSet: StatefulSet.apps "loki-minio" is invalid: spec: Forbidden: updates to statefulset spec for fields other than 'replicas', 'ordinals', 'template', 'updateStrategy', 'persistentVolumeClaimRetentionPolicy' and 'minReadySeconds' are forbidden
Does this mean, I need to re-deploy MinIO with new storage size and then migrate my data? Is this the only way?
