How to implement Flux Queries for annotations
Hi ,
I want have integrated the Flux Db datasource in my Grafana.
I am able to implement the graphs with the help of flux datasource, but i also want to implement the annotations with the flux datasouce.
I my Setting->Annotation->Datascource i am able to see all the other datasource but expect my Flux Datasouce.
Note:- In my old version grafana it is working fine …But it is not working in new version .
I have attach images below…
Thanks in Advance…
I am having the same issue. No idea how to get a Flux query working as annotation.
I have a measurement in InfluxDB2 called ‘syslog’, which contains log entries which I would like to use as annotation.
from(bucket: "R757")
  |> range(start: -12h)
  |> filter(fn: (r) => r["_measurement"] == "syslog" and r["_field"] == "message")
  |> map(fn: (r) => ({_time:r._time, _value: JNUM + "\\" + r.host +" - "+ r.severity + " - " + r._value}))
I add that as an annotation query:
But all I get is the following error when i open the dashboard:
Any suggestions?
I ám stuck also, i can make them in Chronograf from influx, only ik can not copy the source to Grafana like the normal fluxlang in the explorer page from Cronograf to Grafana
It seems, that this issue has not been solved yet - is this the case?
Any progress here? I can’t get it to work either.
