How to implement angular-translate to Grafana?
While I was searching multi-language support in Grafana, I saw the answer which exist in GitHub issue page. Colleague claims that “I have done some research.
I suggest using angular-translate and to do the translation itself in transifex or something similar.” and when I tried to implement angular-translate to Grafana, I could not manage it yet. Is there anybody who implement this library to Grafana before ?
GitHub issue page -> https://github.com/grafana/grafana/issues/448
angular-translate -> https://angular-translate.github.io
Best Regards,
There is no way to do this currently. Maybe after the transition from angular to react is complete
Thank you for reply :slight_smile:
I have got translated .html files from “grafana/public” directory but I found out they are not enough. Most of readable text are inside "grafana/build/.js" in compacted form.
Is it possible to include my translations into grafana?
