Hi folks,
not sure if there is any possible way to address my issue:
10.0.3 running in Docker -
I’d like to use the aggregatewindow function to display data grouped per day, showing the last value provided for that day, BUT omitting zero values -
|> aggregateWindow(every: 1d, fn: last, createEmpty: true) -
What happened?
See screenshot, the value for 16th Aug. is 0
Actually the data is correct, as the last value for this day is in deed zero.
Zero values should be omitted. In this case the last non-zero value should be used. -
see above -
no -
no
