How to hide time series that without data
11:30 - 13:00 has not data, how to hide in panel, my time range is 9:30 - 15:00
Can I create a customize time range?
One can customize the time range using the time selector.
For null values, have you explored these settings?
Also, please state your datasource, as sometimes null values are handled differently depending on the source.
time selector means time picker?
I have try to set connect null values settings. but nothing works.
Yes, time selector = time picker.
Also…
datasource is clickhouse, and 11:30-13:00 get no data
is anybody can help?
Hi @z1198476521
What is the version of your Clickhouse data source?
Hello, My Clickhouse version is 20.4.5.36
You cannot hide 11.30 to 13 on the x axis
alright, i have know it…
Has there been any progress on this issue? I also want to hide sequences without data, such as displaying stock market data where there is no data on non-trading days and times; I want to hide these points.
