Prometheus version 2.49.0 -
I want to be able to have a single prometheus client export network ping data every 30 seconds and speedtest data every hour. -
I have a working python script that hosts a webpage that contains both metrics at the same time -
What happened?
The ping metrics update every 30 seconds, but the speedtest data is also exported. The speedtest data is present as 0 or as the last defined value. The speedtest metrics are also updated every hour
I am wondering what the best solution is here. Do I keep the last defined value and update the dashboard anyway? Do I update the dashboard as long as the value is different? Is there a method to explicitly define what values are new?
I’m new to Grafana, any help is appreciated.
