How to group by month?
Hi experts,
I am using influxdb as data source. This is my query:
SELECT count(“TICKET_ID”) FROM “TICKET” WHERE $timeFilter GROUP BY time(30d), “TICKET_CUSTOM_FIELD_VALUE”
My questions:
  1. If I want to group by month, except using time(30d), any other workaround? Do you support something like time(1month)?
  2. Currently, I rewrite time column in influxdb by DATE_CREATED.
    Now I want to group by DATE_CLOSED(this is a field) and by month, how to implement this? Any suggestions?
Thanks for you help.
influxdb does the grouping, check the influxdb docs for what the group time feature supports
InfluxDB doesn’t support a ‘month’ (1M) as time range … nor ‘year’.
Hence the information in Grafana docs HERE is wrong or at least incomplete. Someone should mention that “M (months), y (years)” does not apply to InfluxDB.
