How to get time information from the grafana alert section
Hi Team,
I created alert rule after that I’m trying to extract the value and used into the summary section. But I could not get time information. How can i get the time infromation?
Hi @guhanrajam1993 ,
Welcome to the :grafana: community forum !!
Can you please provide some more details as what kind of alert you created and whether you are getting these alerts via email or using some other options?
Thank you for reply. I created simple alert only. I created classic condition. If my data is more than 20000, I will send alert notification from the MS Team. I’m getting the alert notification. I writing query based on my db time. I want know that time information.
So basicually you want to view the Database timestamp inside the alert notification firing in the MS Teams.
In this case, you need to define some variables. Please have a look at this post as it might give you more information.
