How to get strings on x-axis on Trend Visualization
Is it possible include strings like a month name (Jan, Feb, Mar) on a x-axis of a Trends panel?
Thanks
I am not sure you can do that.
as it says there an increasing numeric value
Hi Josiah,
Thanks for your attention. Really, I agree. I get a work-around using value mappings from number to text. But only for a small set of needs. For the others, I changed the graphic to a bargraph, where the text is allowed in the X axis.
Best regards,
Roberto
