With the flux query shown above, I can get all query result, which is the organisation name list in the Influxdb explorer, while I can only get tiny part of the query result in grafana as variable. In other words, I can only get a small portion of the organisation name list in the dropdown list.
Is there any way that I can show all the result in the dropdown list in the dashboard?
Is there any way that I can show all the result in the dropdown llst?
I think you are asking if the size of the dropdown can be expanded? In my example below, a vertical scroll bar appears because the list of Part Numbers is quite long. AFAIK, the size of the dropdown box is not adjustable in Grafana.
In my case, the number of the organisation names are more than 6000, but only a small portion (around 500 records) of those 6000 organisation names are displayed in the dropdown list in the Grafana dashboard. With the exact same flux query, I can get full result in InfluxDB’s built-in data explore.
So I am guessing is that there are only limited number of rows that can be shown in the dropdown list in Grafana dashboard or is there any configuration that I can change to display more rows in the dropdown list in Grafana dashboard
@manurodgers If you have 6000 choices and only ~500 are being displayed in the dropdown list, then I would venture to guess that Grafana’s web builder (or whatever it’s called) has a fixed limit on how many choices can be displayed (unlike the Influx Data Explorer, which apparently has no such limit).
This question is best answered by a Grafana software engineer.
