grafana/grafana:8.2.0-beta1 -
I am trying to alert a contact based on the labels that are in kubernetes metrics. I am trying to use these labels in Notification Policy to dynamically choose the contact.
For ex: if pod1 has a label called owner=team1 and pod2 has owner=team2, then I will have 2 contacts, 1 for each team. Then I want to create a Notification Policy to send the alert to Team1 contact if the metric has label ‘owner=team1’. Then same for Team2 if the metric as ‘owner=team2’ -
I am able to send all pod’s labels as part of kubernetes metrics through prometheus. These labels are available in grafana. ex:
kube_pod_labels{app_kubernetes_io_instance=“prometheus”, app_kubernetes_io_managed_by=“Helm”, app_kubernetes_io_name=“kube-state-metrics”, helm_sh_chart=“kube-state-metrics-3.4.2”, job=“kubernetes-service-endpoints”, kubernetes_name=“prometheus-kube-state-metrics”, kubernetes_namespace=“default”, kubernetes_node=“minikube”, label_app=“rkadekar”, label_pod_template_hash=“7d5655b9b4”, label_owner=“Team1”, label_test2=“test2”, label_test=“testing”, namespace=“default”, pod=“hello-world-7d5655b9b4-bmmmf”}
I am trying to use these labels in Notification Policy under matching labels section. So I can dynamically route the alerts to right contacts.
What happened?
Notification policy doesn’t recognise these metric labels. It only knows Alert’s custom labels. So its not able to route it dynamically. -
I exected Notification policy to recognise these labels -
