Context:
Alert rules execute SQL queries that return multiple rows (entities). Grafana creates an alert instance for each row, evaluates conditions, and sends only Firing instances to Alertmanager → Contact Points.
Problem:
I need ALL instances from query execution results - not just Firing, but also Normal/Pending states. Grafana must store this data somewhere between query execution and sending to Alertmanager, otherwise it wouldn’t know what to send.
What I’ve tried:
/api/ds/query- re-executing SQL queries works, but it’s slow and returns duplicates
Questions:
Where does Grafana store alert query evaluation results before sending to Alertmanager?
Is there an internal database/logs with complete evaluation results?
Maybe Grafana IRM or another integration provides access to this data?
Goal:
Build a dashboard showing: alert rule → all monitored entities → their current values and crit. values.
Grafana version: v12.0.1
