I’m working on integrating Speakatoo’s services and need guidance on the correct way to include the API key in the headers. Does it require a specific format like Authorization: Bearer <API_KEY>
or another structure? Any insights or examples would be helpful. Thanks in advance!
It’s used in the request headers like this:
You need to pass API Key in the HTTP Authorization request header as ‘X-API-KEY: YOUR-API-KEY’. Your Content-Type header should be ‘Content-Type: application/json’.
I’ve never used this service so I’m just repeating what the documentation is saying.
