We have a single stat panel on one of our dashboards. The statistic is counting tens or hundreds of thousands of items, and is a bit hard to read with so many digits:
How can we format the output string, so that it has commas?
That’s not supported. However, if you find this feature really helpful I would suggest you to create a feature request issue. Please search open/closed issues for similar issue before creating a new one.
If enough of people upvotes the issue with a thumbs up emoji we’ll consider implementing/merging it.
Marcus
