Hello Grafana community!!
I have some dynamic bar charts, and I want them to maintain the descending order formatting whenever they are updated.
Is it possible?
Thanks.
Is it possible?
Thanks.
Yes, you can sort a bar chart in descending order following these steps :-
Add transformation → Select “Sort by”
Field: Select the field you want to sort
Order: Set it to Descending.
