How to filter values in a status history panel with two queries
I am currently building a dashboard in Grafana (9.0.6) and try to visualize “AWS Lambda Invocations” and “AWS Visible SQS Messages” with two queries (Metric Search) in a status history panel over the last 24 hours.
Problem is that the SQS Metric has far more datapoints, than the Lambda Metric with datapoints for actual invocations.
Question: Is there a way to filter out the values equal to 0 from SQS, to see the actual timeframe where something happenend over 24h?
Right now i use Metric Search and played around with data transformations without success. Metric Queries cannot not be used, as it is limited to the last 3 hours.
