How to fetch distinct/unique values from logs?
Hi Community,
Is there any way to get the distinct/unique IPs from the logs? This query count the logs but I need it to be counting the unique IPs. I don’t see any operator to achieve this result.
count (
                count by (ip)(
                        count_over_time({component="controller", instance="ingress-nginx"}
                        [$__interval])
Regards,
D
Do capture the IPs as labels while collecting the logs?
If not, it possible to achieve what you need with LogQL pattern parser [and Grafana transformations].
Can you show us some of the logs?
