I have docker-otel-lgtm stack running on EC2 instance. What I need is to send Lambda logs to the OTEL collector so I can query the logs using Loki. Any guidance on how to configure the docker and additional steps on Lambda. I have already added the Lambda layer having otel-python and below is the compose.
version: "3.8" # Specify the version of the compose file
services:
lgtm:
image: docker.io/grafana/otel-lgtm:0.8.2
ports:
- "4317:4317"
- "4318:4318"
- "3000:3000"
environment:
- GF_SERVER_ROOT_URL=https://logs.xxx.com
- GF_AUTH_ANONYMOUS_ENABLED=false
- ENABLE_LOGS_OTELCOL=true
volumes:
- lgtm_data:/data # Mount the Docker volume to the /data directory in the container
- otel-lgtm:/otel-lgtm/
volumes:
lgtm_data:
otel-lgtm:
