How to enable auto-delete logs?
Hi! I try enable auto-deleting, but all options which i found on page Grafana Loki configuration parameters | Grafana Loki documentation have no effects.
Running on docker, filesystem storage.
loki-config.yaml:
auth_enabled: false
server:
  http_listen_port: 3100
  grpc_listen_port: 9096
  log_level: debug
  grpc_server_max_concurrent_streams: 1000
common:
  instance_addr: 127.0.0.1
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /tmp/loki/chunks
      rules_directory: /tmp/loki/rules
  replication_factor: 1
  ring:
    kvstore:
      store: inmemory
query_range:
  parallelise_shardable_queries: true
  align_queries_with_step: true
  results_cache:
    cache:
      embedded_cache:
        enabled: true
        max_size_mb: 100
limits_config:
  metric_aggregation_enabled: true
  reject_old_samples: true
  reject_old_samples_max_age: 10s
  retention_period: 10s # 1
compactor:
  working_directory: /loki/compactor
  compaction_interval: 10s # 1
  retention_enabled: true # 2
  retention_delete_delay: 0s # 3
  delete_request_store: filesystem # 4
  delete_request_cancel_period: 10s # 5
  delete_max_interval: 10s # 6
table_manager:
  retention_deletes_enabled: true
schema_config:
  configs:
      store: tsdb
      object_store: filesystem
      schema: v13
      index:
        prefix: index_
        period: 24h
pattern_ingester:
  enabled: true
  metric_aggregation:
    loki_address: localhost:3100
  flush_check_period: 1m
ruler:
  alertmanager_url: http://localhost:9093
frontend:
  encoding: protobuf
docker-compose.yaml:
services:
  loki:
    image: grafana/loki
    container_name: loki
    command: -config.file=/etc/loki/config/loki-config.yaml
    volumes:
      - ./loki-config.yaml:/etc/loki/config/loki-config.yaml
      - ./loki-data:/tmp/loki
    ports:
      - "3100:3100"
  grafana:
    image: grafana/grafana
    container_name: grafana
    ports:
      - "3000:3000"
    volumes:
      - ./grafana-data:/var/lib/grafana
    depends_on:
      - loki
If you are using recent version of Loki, you’ll want to disable table manager and use compactor only.
